azeiler wrote:I just had my 06 M35’s fluid changed at 60,000 miles by a local tranny shop (Automatic Transmission Factory in Davie, FL). They removed the pan, then drained and inspected the torque converter as well as the valve body. Then they refilled using Amsoil synthetic (around 14 quarts) and a bottle of Lubeguard. What a huge difference!!! The tranny shifts smoother when I drive nice, but kicks harder when I jump on it. I never expected these kinds of noticeable results just from switching fluids. I think the cost was around $175.
For a car this expensive, I don't understand why anyone would try to cut corners by partially replacing fluid intermittently. I understand the need to save money, but IMHO the tranny is not the place to do it.
Thats definitely worth the money in my opinion. Mobil 1 fluid alone is $9 a quart. U basically spent a few bucks for them to do the work.
When I had my harmonic balancer replaced at the dealer, they had an offer for ATF change $59. Figured why not, I cant even buy the fluid for that. Ended up being pull the plug, let it drain, and refill. Not thrilled.... to say the least. Now that the weather is getting nice i may take Billys fantastic write up and replace the fluid with Amsoil or Mobil 1.
