autoengr »
https://forums.nicoclub.com/autoengr-u160226.html
Wed Nov 16, 2011 11:12 am
There is a school of thought that if you have waited past the recommended change interval, you should avoid changing the fluid. The anecdotal experience was that after removing the fluid heavy with suspended particles from the friction plates, the transmission would start slipping.
In my opinion using this as a justification to leave old fluid in place is faulty logic - it is like finding that you have high cholesterol and neglecting to change it. Or worse, attempting to change lower it through diet and exercise and then blaming a subsequent heart attack on the change.
The bottom line is that fluid wears out over time and needs to be changed. If it is overdue, it should still be changed. The next question of drain+fill vs flush is separate. I felt better about doing multiple drain+fill routines on my overdue G35. I felt OK having a shop flush my M35x on the regular service schedule.
