loystock »
https://forums.nicoclub.com/loystock-u10145.html
Sat Mar 27, 2010 3:57 pm
Spec for ATF (10 quarts capacity) is Nissan Matic-D but Dexron III and the latest Dexron VI should work. You can also go for the more expensive Mobil 1 ATF or Amsoil. After the transmission service, add a bottle of LubeGard Red ATF Protectant (@ $13 from Napa).
Spec for P/S fluid is Dexron II and again Dexron III should work.
