bmlawless described it earlier:Joe99qx4 wrote:all, I have the 99qx4, with 3.3l, 4wd. What doyuou mean by flare? Mine shifts hard from 1st to second and shifts slow from 2nd to 3rd. Are you experincing the same thing? And did cleaning the MAF fix this?
I usually see this on the 2-3 shift.bmlawless wrote:Flare is when the transmission slips just before shifting. If you watch your tach, you'll see your rpm's increase suddenly just before the shift occurs.
I have your same problem... it happens often, but not always.... The vehicle doesnt "bang" into second gear with noises or clunks or anything like that... it sort of lurches forward aggressively, kind of like a manual transmission would do if you rev too high during the shift. Only does it from 1-2, and again it only does it at low RPMs/speeds, and even again it doesnt happen on every low RPM 1-2 shift, but it does happen often.01qx4bad wrote:Hi new to this board,new to owning infiniti.Have a 2001 infiniti Qx4 with 130k on the odo.I'm the second owner and I noticed this flare shift from 2 to 3 in low speed conditions,but in a parking lot, going less than 20 kph (canadian vehicle) in first gear at 1500rpm the engine bucks(kind of missing feeling)before shifting into second gear.When driving on the street stop light to stop light no problems because I'm over the 1500 rpm.Bought this vehicle because 1st owner hated this problem and the dealer could not fix it,lots of new parts,tps,trans service with new screen and soleniod packs,complete tune up,no coils,and no codes are given,other wise this truck runs awsome.Anyone have this same problem before?
There is no similar TSB for Maximas or I30s. One for a harsh 1-2 shift appeared for some reason, but in the TSB it states that it only affects 2003-2004 Maximas (A33 and A34), vehicles built between December 1st, 2002 and August 27th, 2004, and the RE4F04B and RE4F03B transmissions. I don't know why this would appear under a search for 2001 Maxima, but if you'd like to take a look at it you can download it here.ashman2k2 wrote:I have a 2001 Infiniti i30t and it has the same flaring between gears...I absolutely hate it. Been driving it for years like this...In the recent years it actually squeals during the flare...What makes sense to me is that the flare is exactly a clutch slipping (not enough pressure/delay in full pressure) and over time it has worn out the clutch material and now squeals during slipping.
Is there seriously no diagnosis? It seems like during these years all Nissan transmission were having issues like this. No TSB?
Sticky valve body? Bad solenoid? or bad trans ecu programming?
You can try throwing in a bottle of Lubegard Red; it's well lauded by transmission shops and can help lower transmission temperatures. I'd also suggest the installation of a Magnefine in-line filter (the link says power steering filter, but AFAIK Magnefine's P/S and trans filters are identical) to prolong the fluid and transmission life. What kind of fluid did you use for the drain & fills?bucksluts wrote:I've had a similar flare issue into second and third on my 01 pathfinder when the truck is cold (below 50F) for nearly 100K (current mileage 191K), but its gone within a few minutes once warmed up. I've changed the fluid a couple times (pan only) but the flare stayed the same.
