elwesso wrote:The heat load from the trans won't affect your coolant temp.. If you're getting up to the 220°F range I would say you're probably ready for a new radiator.
hello,
i just had new rings and head gasket installed, new nismo thermostat , new KOYO oem radiator installed.
still it goes as high as 220F when im pushing the car on a drag strip, but it does come back down when i drive normally.
