firemed55 »
https://forums.nicoclub.com/firemed55-u57975.html
Thu Feb 28, 2008 12:23 pm
So I found a transmission control module to hopefully solve my issues. I priced new ones. From a dealer its like 500sih and a wholesaler its like 400ish. I found a QX4 with rear damage which was deemed totalled. The Transmission control module from that was tested and was being parted out for under 100 dollars. The tranny on the totalled QX4 had about 100k miles. My question is this. The tranny goes through wear and tear but in all theories the control module just tells it when to shift, so it should still be ok if it was tested yes? Secondly, in the service bulletin for this is also says to replace the solenoid assembly. What does this do and how would I know if it is messed up to. Don't want to spend cash on something that may not be messed up. Any thoughts?
