IMH »
https://forums.nicoclub.com/imh-u110135.html
Wed Dec 31, 1969 5:00 pm
Jefe De Jefes wrote: Quote »Well , I picked up the mounting plate and the flywheel from the 1979 200sx to go with the dogleg I plucked from it. I will go new with the starter, clutch and pressure plate.Thanks for the input.[/quote]The 200SX flywheel isn't going to fit your E1. I'm not sure about the 200SX mounting plate. It may work with some modification. The mounting plate and flywheel on mine are JDM items that would be hard to find. They came with the JDM J16 engine. You'll need a J13 flywheel and the earlier 200mm clutch from a 510, 521, or early 620. I'm pretty sure that the 200SX unit is 225mm. Measure the clutch disc. If it's 7 7/8", it can be used with a J13 flywheel, if it's 8 7/8', it can't. And the stock flywheel from your truck is designed for a 184mm clutch so it won't work either.
