hospitalbuilder »
https://forums.nicoclub.com/hospitalbuilder-u93818.html
Sat Aug 22, 2009 5:15 pm
Very easy. Get some MAF cleaner (specifically for the MAF at your local auto parts shop). Then remove the MAF, a three inch section of tubing attached to the clean side of your air filter housing. You have to remove the wiring to the MAF, but leave it in the tubing, it is not terribly sturdy, and easily damaged. Spay both sides of the MAF liberally with the cleaner, let it dry and reinstall. All done, easy as pie.
