I finally got permission to resume normal activities after my surgery so I set out to adjust my TPS from .48v to .44v. My 94 Q requires a 7mm wrench and a ratcheting wrench is the way to go. After warming it up to 176 F, I made the adjustment using ECU Talk and set it to .44v. It was very easy.
I took it for a drive and I noticed some strange things going on. It was idling over 1000 rpms and the timing was at 26 degrees BTDC and did not run very well. I tried resetting the timing but did not have enough room to get it down to 15 degrees. The IACV was over 35 and I was getting really frustrated. I got back on this forum and did some searching and found this thread
post5839478.html?hilit=throttle position sensor#p5839478
that says that the above can happen if the ECU does not get a Closed Throttle signal. I would guess it thinks you are driving along and advances the timing and opens the IACV.
I remembered that earlier I had adjusted the Throttle Drum Cable. Per the FSM, you make it tight and then loosen the nut by two turns. When I did this it seemed to have too much slack and I was only reading 3.83v on the TPS when floored. Sooooo, I tighted it about a turn to get it to read over 4.00v and I think this caused the problem with the Closed Throttle Switch.
Today I readjusted the Throttle Drum Cable to two turns back and the idle cam down, the timing was closer to normal and the Idle was in the 700 range. I used my inductive timing light to reset the base timing to 15 BTDC, adjusted the IACV to get base idle to 600. I also put my cleaned OEM PCV back in per Infinitiguy19’s recommendation. The car was a Q45 again and my hard 1-2 shifts were gone and it ran really well.
Sorry for the long post but I wanted to let those who helped me know that they did, to share my adventure with the throttle cable and to thank those who have posted so much great information on this forum so that someone with average mechanical ability can continue to enjoy this great car and feel a sense of accomplishment.
