XterraVersa wrote:Explain how tinting would affect a TPMS?
The status of the pressure transducers (in the wheels) is checked by the car computer by a radio signal...e.g., it's wireless. The antenna used by the computer is apparently inside the cabin of the car. The steel body of the car shields the RF signals from the transducers, so their only path is via the windshields (glass lets the RF through).
Theoretically, then, a metallic tint film on the windows would ALSO act as a shield, and will block the signals from the wheel transducers.
It sounds like TPMS problems are getting fairly widespread in the automotive community. I found a couple of companies selling universal TPMS-reset tools to repair shops and tire dealers. Enter the car type, attach the right connector, and it resets the TPMS.
Kinda bodes ill in the search for a simple reset that owners can do....
The TPMS is now required by the EPA, so there's no getting away from it. According to one source I found online, the EPA requires that the system be incapable of being turned off! So the dealer is apparently not going to be able to just kill the thing, and, apparently, the manufacturers are ensuring the TPMS share a fuse with a vital system. So you can't just pull a fuse to kill it without otherwise crippling the car.
Ron
