shynepo3https://forums.nicoclub.com/memberlist.php?mode=viewprofile&u=113&sid=b3a742e3af5f17070759cbc9a1534e6cTPMS not reading one tire, warning light on, qx56 2006Sun Dec 19, 2010 11:36 pm
Postby
shynepo3 »
https://forums.nicoclub.com/shynepo3-u134349.htmlSun Dec 19, 2010 11:36 pm
My 06 qx has the tpms warning light on. All four tires have air, around 35-40 psi. It's cold here in Toronto , but that doesn't explain why only 3 tires are registering when I chec the tire pressure readings on the qx56 screen.
Any ideas? Is there a way I could reset it? I hate to take to a dealer....I'm out of warranty I think. Thx for ant suggestions
Postby
shynepo3 »
https://forums.nicoclub.com/shynepo3-u134349.htmlMon Jan 10, 2011 12:14 pm
it's steady, but when i check the tire reading screen, 1 tire is not showing a reading at all ...it shows "--". but the pressure is fine for all 4, and in the past, if one was low, it would show the low reading anyways.
one of the sensors must be dfective or loose or something...any quick fixes?
