motoguy128 »
https://forums.nicoclub.com/motoguy128-u46857.html
Tue Dec 12, 2006 5:16 pm
It's disappointing that Nissan wasn't able to make this system cheap and reliable. I'm only at 1500 miles so it's too early to know if I will be affected, but I have an S model (not sure if that matters) and I think my car was built several months after yours... so maybe they fixed it. I haven;t heard of as many new cases (that weren't actually caused by low tire pressure). I suspect that sometime around September, most cars comming off hte assembly line had an "updated" part. Why Nissan is not willing ot replace you part to solve this is beyond me.
On a side note, some '07 BMW motorcycles are also comming with a TPMS system as an option, but there, I think the pressure is simply measured using the ABS sensors to detect if one tire pressure has changed in relationship ot the other on level surfaces when the RPM's are steady. Traction control/stability control is also offered (again part of the ABS system).
I think TPMS, will become a standard feature like front disc brakes. As ABS becomes standard, I suspect stability control and traction control will also be standard within 2 or 3 years. I think the government may mandate it soon.
