breadbox wrote:So it can't tow a car? What does that mean? 1000 in total?
I didn't say you CAN'T, I said the manual says you SHOULDN'T
Personally I wouldn't tow much of anything with my 720 just cause of that fact, I'm afraid it'd shorten my transmission's lifespan. Here is a more full excerpt:
From the '81 manual:Never exceed value for trailer with brakes is 2000lbs, 1000lbs for trailers without brakes. Maximum gross combined weight shouldn't exceed 5000lbs (5400lbs for 4wd models).
Max tongue load is 10% of trailer weight, and should be considered part of cargo load and gross axle weight rating.
Max cargo payload (not trailer) is 1100 pounds for all models, and rear max gross axle weight is 2400 pounds.
