RideNslidE »
https://forums.nicoclub.com/ridenslide-u56833.html
Fri Dec 24, 2010 7:15 am
I didn't write this but it was helpful for me
CAM BOLT Removal/Installation
Removing the cams in order is essential (as well as other bolts) as to not warp the head. This really goes for all items securing them selves to the block or head.
Reverse this sequence to remove cam bolts:
12..8...4...2...6...10
O--O--O--O--O--O
O--O--O--O--O--O
11..7...3...1...5...9
<---Front
To tighten follow the above sequence in two steps.
1. 1.4 lbs/ft
2. 8.7 lbs/ft
HEAD BOLTS Removal/Installation
Reverse this sequence to remove head bolts:
9....3....1...6...8
O--O--O--O--O
O--O--O--O--O
7....5...2...4...10
<--- Front
To tighten follow the above sequence in Five Steps:
1. 22 lbs/ft
2. 59 lbs/ft
3. loose all bolts completely
4. 25 lbs/ft
5. 65 lbs/ft (80 lbs/ft for ARP studs #202-4206)
ROD BEARING Removal/Intsallation
Loosen in two steps.
Tighten in two steps:
1. 10 - 12 lbs/ft
2. 28 - 33 lbs/ft
MAIN BEARING Removal/Installation
Follow this sequence to remove the Cage/Main Bearings Caps.
1....5...9...7....3
O--O--O--O--O
O--O--O--O--O
2....6...10...8...4
<---Front
To tighten follow this sequence:
7....3...1....5...9
O--O--O--O--O
O--O--O--O--O
8....4...2...6...10
<---Front
Tighten in two to three steps up to 46 - 56 lbs/ft.
Other Torque Specs
Crank Pulley: 150 lbs/ft
Cam Gear: Intake: 167 - 177 lbs/ft
Exhaust: 66 - 82 lbs/ft
Timing Chian Guides: 17 - 19 lbs/ft
Upper Timing Gear: 66 - 82 lbs/ft
Chain Tensioner (all): 7 lbs/ft
Upper Front Cover: 17 - 19 lbs/ft
3 downward: 9 lbs/ft
Oil Pump: Upper 6: 17 - 19 lbs/ft
Lower 3: 7 lbs/ft
Flywheel: 110 lbs/ft
Happy building!
