Still in the works, but this is the first engine startup
XTZTwinTurbo
Car: 1991 300zx TT with LOJ Innovations LSx swap kit
[youtube]https://youtu.be/-meTbYpx5L0[/youtube]
The exhaust tips are not on in this video, so that is why you see the smoke wafting around, underneath the backend.
Specs:
1991 300zx TT with LOJ Innovations LSx swap kit, installed a LS3 engine.
STS (Squires Turbo Systems) rear mounted turbos with Ball Bearing Turbo Upgrade 1200 HP capability.
Custom intake piping work from rear to front Z1 B.A. Side mount Intercoolers
Machine Work:
Line Hone
Bore and hone head work
JE FSR Pistons
Manley Pro Series I beam Rod
1250HP Turbo Cam
Comp Cams GM LS Trunion Bearing kit
ARP Cam Bolt Kit
Manley Extreme Duty Valves
Manley Pro Flow Oil Pump
LS ARP Head Stud Kit
(2) Walbro 450lph E85 Fuel Pumps
Fast LSXR Fuel Rail Kit
ID 1300cc injectors
Kooks block-hugger headers
Fast 120mm intake
Nick Williams 102mm black electric throttle body
Katech timing chain
GM OEM-Engine Timing Damper 12588670
Maniac Motors: 140 AMP High Output Alternator
98+ Spec Z32 TT Transmission
Shaftmasters Aluminum Light Weight Driveshaft
Clutchmasters Twin Disc Clutch for LOJ Swap Kit
Full Powertrix suspension with Hicas delete bar
Z1 solid aluminum rear subframe bushings and SPL solid aluminum differential bushings.
Stillen rear Strut Tower Brace
SPL fender braces
Tein Flex Adjustable Coilovers
Z1 SS break lines
Full Strosek style widebody kit.
99 spec headlights
99 Jspec Tail lights and rear center panel
PIAA 73270 LP270 2.75" Led Light Kits Fog Lights
MRR Racing, GT-1 wheels. Staggered 19x9.5 front and custom widened 19x13 rear wheels by Weldcraft Wheels.
Wheels have been powder coated (Bronze):Melted Bronze lip with (Grey):Ultra-Black-Chrome face.
Z1 Hubcentric aluminum spacers
Nitto tires:
Front: 265/30ZR19 Nitto Invo Tire 93W
Rear: 315/25ZR19 Nitto Invo Tire 98Y
DBA Brake Rotor Slotted Rotor 5000 Series T3 (52314BLKS)
DBA Brake Rotor Rear Slotted Rotor 4000 Series T3 (42315S)
09-16 nissan 370z oem front & rear big Akebono brake calipers
CZP Akebono Bracket Adapter Kit
Disc Brake Pad-Street Brake Pads Rear STOPTECH 308.13470
Disc Brake Pad-Street Brake Pads Front STOPTECH 308.13460
Click on the link to see updates and to follow my page:
https://www.facebook.com/XTZTwinTurbo/
.[/QUOTE]
centralcoaster33
Car: 1997 Nissan 240SX #5
Cool project and interesting piping configuration! Welcome to NICO Club.
XTZTwinTurbo
PapaSmurf2k3
Site Admin
That's an amazing project!
Welcome to NICO :)
Ace2cool
Car: 1991 Nissan 300ZX TT
1966 Datsun Fairlady 1600
2005 Suzuki GSX-R 600
1974 Honda CB550 Four
2009 Ford F150 Lariat
Oh, too cool. Some crazy fab work in the back. Beautiful.
PapaSmurf2k3
Site Admin
How does the oil system work for the turbos?
