TPMS what brand ?
Danoutwest
Car: 2006 Infiniti M35 Sport
I want to replace my TPMS units, is there a particular brand I should by for this car?
Thanks
Ilya
I'd stick with OEM from eBay. Just verify the model number, etc.
EdBwoy
I would also consider Schrader branded ones, if you want new. Schrader is the godfather of putting air into pressurized systems.
A lot of OEMs just rebrand their stuff.
Ilya
EdBwoy wrote:I would also consider Schrader branded ones, if you want new. Schrader is the godfather of putting air into pressurized systems.
I think this is the brand Tirerack sells. I had them on my M35x I think.
Danoutwest
Thanks for the feedback, I picked up some Schrader's on e-bay.
EdBwoy
Great! Let us know how they work out.
Do you have any specifics on them like frequency rating or model/part number?
ae7456t
Car: 2006 M35X with 19X,XXX miles
FWIW...I had to replace a dying TPMS sensor last summer when getting new tires and went with this one from Amazon...
https://www.amazon.com/gp/product/B00CB ... UTF8&psc=1
Seems to be working well, so far.
Also replaced one during the prior tire change with what they had at Advanced Auto with good results, as well. The Amazon one was cheaper, so went that route the second time.
jasejase
Oem or tire rack.
bluedevil30
Car: 2009 M35X
265,000 miles
Recently, I had 2 TPMS sensors replaced by a large chain tire store on my 2009 M35X. The car failed to receive the TPMS signal and showed ***. I had to go back 2 times and call the sensor mfg. customer support before we resolved the issue.
Just because a tech's tool (Bartek) is receiving the TPMS signal doesn't mean the car is. In order for my M35 to receive the signal, my car's TPMS computer had to be reset using the tool. Only then did the car see the new sensors.
Costee
Car: 2006 Infiniti M45 Sport
2012 Nissan Murano SL
bluedevil30 wrote:Recently, I had 2 TPMS sensors replaced by a large chain tire store on my 2009 M35X. The car failed to receive the TPMS signal and showed ***. I had to go back 2 times and call the sensor mfg. customer support before we resolved the issue.
Yes, the tool does two things: receive the sensor signal/ID, and then write the ID to the tpms control unit.
