I wouldn't necessarily order a coil yet, I'm surprised you have a noticeable misfire with no code. If it returns, swap the coil with another and see if it follows it, unless you're just wanting to replace it. Sometimes when you have a miss on first cold start it can be a sign of coolant pooling in a cylinder from a possible head gasket. One of the other techs is currently replacing a head on an FX50 for symptoms similar to yours. Not to freak you out, as that would be EXTREMELY uncommon.Tim/M45 wrote:I did not change the coil yet. It has been running fine today. Missfired and sputtered a bit first timeout yesterday after changing the plugs, but no problems today. Also, I was finally able to do the throttle relearn successfully this afternoon. The car is running well, for now. I will drive it this week. If it missfires again I will order the coil. Still not sure which brand coil to get.
The TB was wet with oil residue when I did the plugs, so I am leaning towards installing the oil catch can. I imagine the intake is pretty nasty downstream from there. nAny suggestions on cleaning that?
Thanks to all who gave their input. I love this car. I have been looking for one in decent shape that I could afford for the past 2 years and am very happy to finally have one.
My coils are Hanshin, and maybe someone might be able to offer counter-Intel on this, but I've not noticed many, if any issues with the coilpacks on our cars. Knowing that someone replaced that one coilpack, seems to call to another issue that someone tried to remedy with a coilpack(ever find out who the manaufacturer of that coil was, Duralast perhaps?). How's the injector firing at startup?Tim/M45 wrote:I did not change the coil yet. It has been running fine today. Missfired and sputtered a bit first timeout yesterday after changing the plugs, but no problems today. Also, I was finally able to do the throttle relearn successfully this afternoon. The car is running well, for now. I will drive it this week. If it missfires again I will order the coil. Still not sure which brand coil to get.
Ya, coil issues are few and far between. PCV issues are also uncommon, but they can cause oil in the intake and throttle body. A light coating on both is normal though, I've never had an intake off that didn't have oil in it. A check engine light can be tripped instantaneously, especially for a misfire. Other codes can take various amounts of time to trip it, so you're not totally off base.EdBwoy wrote:My coils are Hanshin, and maybe someone might be able to offer counter-Intel on this, but I've not noticed many, if any issues with the coilpacks on our cars. Knowing that someone replaced that one coilpack, seems to call to another issue that someone tried to remedy with a coilpack(ever find out who the manaufacturer of that coil was, Duralast perhaps?). How's the injector firing at startup?Tim/M45 wrote:I did not change the coil yet. It has been running fine today. Missfired and sputtered a bit first timeout yesterday after changing the plugs, but no problems today. Also, I was finally able to do the throttle relearn successfully this afternoon. The car is running well, for now. I will drive it this week. If it missfires again I will order the coil. Still not sure which brand coil to get.
Might you have also replaced the PCV? One symptom of faulty PCVs is oil on the intake air side, like throttle bodies.
Oh, and also I believe the car needs at least 2 key-ignition cycles to throw a code. If all is clear, I would run some seafoam to clean up. I've had success with the product personally.
You can do it that way, or you can run it through the PVC hose. If you've never done it before, there's a super fine line of using too much and causing it to stall, so just go easy with it. I haven't done my Infiniti, but I did my old 4Runner with it. It didn't smoke much during the process, but if you let it sit a while after you do it it'll smoke like crazy when you first start it, so be prepared for that.Tim/M45 wrote:I only noticed the missfire after the engine was warmed up. It was so bad I returned home and left it there until I could change the plugs. I only got the one missfire code. I did put the suspect coil pack on a different cylinder when I changed the plugs. My coolant level is steady, it is my oil consumption that concerns me next. I will fix the leaking valve cover gasket and install the catch can (and replace PVC valves) next.
As for the Seafoam, do I hook up to the PVC input to the TB?
I usually use the vacuum input from the brake booster to the intake manifold, after the check valve... but I wouldn't do the seafoam in this case yet.Tim/M45 wrote:I only noticed the missfire after the engine was warmed up. It was so bad I returned home and left it there until I could change the plugs. I only got the one missfire code. I did put the suspect coil pack on a different cylinder when I changed the plugs. My coolant level is steady, it is my oil consumption that concerns me next. I will fix the leaking valve cover gasket and install the catch can (and replace PVC valves) next.
