Well, here's sort of as an update with my experience, and sort of a bump to your question. I ended up getting a wifi PLX Kiwi from Amazon. I've tried a total of 4 applications. On the iPhone (5 with ios 8.1.3) I tried
DashCommand and
OBD Car Doctor. On my laptop, I tried
OBD Auto Doctor and
Movi Pro. Both of the devices are able to connect to the network with no problem.
Neither of the iPhone apps are able to connect. DashCommand connects, tries to open the port, and immediately disconnects. OBD Car Doctor hangs indefinitely while trying to connect. I've tried many, many times with absolutely no joy.
On the laptop, Movi Pro is able to connect, but doesn't retrieve any information, All of the information pages and panes are blank, and the app constantly freezes when switching between them. I went ahead and spent the $40 on OBD Auto Doctor, but with similarly depressing results. The application connects, seems to communicate, but delivers precisely no information (engine running or not) except battery voltage.
The even more depressing finding was that OBD Auto Doctor (laptop) worked perfectly with my wife's 06 Camry. It delivered all sorts of numbers and measurements for each of its sensors and the application was even able to detect the car's year and the VIN.
Thinking this was a problem with the Kiwi, I arranged for a cross-ship and currently have tried both units with the same results.
I don't
think there's a problem with my OBD port, but I'll be taking a closer look later to be sure. The device powered up upon connection, and the software knew when the key wasn't turned to on, so I can rule out fuses/power being the issue.
On a somewhat related note, testing was constantly exacerbated by the horrible connector on the Kiwi. The outer rubber portion of the connector is far too tight and makes the connector difficult to insert, and as a result the two longer ground pins are constantly getting bent. This wouldn't be too much of a problem if you're planning on keeping it connected all the time, but plugging it in was a great source of frustration.
Needless to say, I'm bummed. I've spent close to $150 on the adapter and the software, and have nothing to show for it. A lot (all?) of the people I've seen here that have used bluetooth and other OBD adapters with their phones and such have pre-2001 vehicles, so I'm wondering if the 2001-04 crowd is just KSOL
