I did it!!! Holy Shiznit is it loud when open.
I can feel better acceleration at highway speeds, no question. Off the line, I don't notice any degredation or improvement.
The wiring for power to the actuator was a piece of cake. I had a spare grommet to seal off the hole I drilled and put the receiver under the driver's seat. The kit comes with a cig lighter power connector with loads of wire length and while I'm still getting used to it, I'm just using the power access in the center console. I'll probably tap into a 12v power supply after I knock out a few things that have priority.
Having a remote control for it is cool as hell.
It's loud as NASCAR! The down side is that when closed, the butterfly is thin enough that you still hear some exhaust note and though it's not unplesant, I'd rather have it dead stock sounding when the actuator is closed. I may see if I can build up the area around the butterfly to thicken it a little against the leaking exhaust noise. Did I mention it's LOUD when open?
At highway speeds when closed, It's quiet as stock inside, but when cranked, idling or driving around town, you can tell there's something unusual about this M.
Theres also no ability to use a half open setting or adjust for sound. It's all or nothing. For around $100 plus shipping, I'm OK with that.
I had the shop take out the resonator after the cats and they had to adjust the collection point a little to get the cutout assembly to fit correctly. Pretty simple really. I kept the resonator to add back in case the unit fails or I get sick of it....but not anytime soon!
The wife hates it and refuses to drive it anymore, so there's another win.
I'll get up some vid when I can (if requested), but there's already a Utube clip out there of the same thing from someone else... My pics are here...
http://s302.photobucket.com/albums/nn10 ... %20Cutout/
