300Plus »
https://forums.nicoclub.com/300plus-u30494.html
Tue Jul 24, 2007 9:15 am
I copied this over from the racebread convo since I've got a lot of questions about it. I will add to it as more comes along. The wiring I have mostly figured out, and now me and Darius are comparing notes to find the best way to make everything work, so one of us will post up the wiring info as soon as completed.
here are a few quick pics.
the line on the left (labeled as 1) is the stock S14 line, the line on the right (labeled as II) is the RB hose that was cut when I got the compressor so I don't know if it would work if it were complete But anyways... as you can imagine I am going to have the two lines connected with 6.5 inches of rubber in between.
zoomed out (pay no attention to the dirt )
Now B is the long line that runs behind the head along the firewall. I think it will work with just swapping the ends for the rb compressor, but it would be a little close to the exhaust for my taste. I think the best option would be when you swap the rb end on A just have them add more hose on that end. In the pic the stock s14 line B has a muffler on it, which I think I will eliminate and just have the RB end A welded on.
zoomed in
Now the 3rd line on the passenger side runs the from the s14 condenser to the S14 firewall so it doesn't need to be modified, just bent by hand a little. I have a greddy manifold so I had to bend it a little more to push the drier down beside the frame rail. I do not have pics of this right now but the line bends very easily and can easily be figured out. **Remember the drier has to be replaced if your ac system has been opened for more then 24 hours, which is most of us. I do not think they are serviceable but I will confirm later this week when I talk to the shop.
**EDIT**I now have the AC lines welded up (as described above) and everything fits perfectly. I will have pics of them up soon!Hope these help guys more to come on the wiring and the lines.
