Thanks!
If this is a common issue? anyone else have this problem? Maybe a write up would be good if so!
Do you have to lift away the outer lid of the door while it is unscrewed from the hinged inner section? Or is the whole lid assembly going to come off (somehow) in one piece? What direction does it pull out?
If it is the whole box that is being removed, where are the screws holding it in place...nothing obvious or reachable?
There is nothing that looks like it can pull apart, it just feels like the plastic hinge will break if I pull it hard! Per the diagram the hinge is screwed in from above...not seeing how this comes apart at all!
I see no clips visible?
tollboothwilley wrote:I had the same issue with mine and it pissed me off until I figured it out.
As long as you have removed all the screws then you will pull it out from the left side while pushing it to the right.
Make sure that you don't have any screws holding the piece in.
It might require more force than you'd expect...just make sure you pull the left side out first.
Modified by joshcloud9 at 10:40 AM 3/25/2008
Modified by joshcloud9 at 11:30 PM 3/25/2008
