kevindanielk »
https://forums.nicoclub.com/kevindanielk-u42212.html
Mon Mar 17, 2014 12:17 am
White90esex, I managed to drop and replace my 95 G50 tranny without moving or unbolting anything at all, from the engine. I did have to unhook the exhaust from the back, letting it hang down and allowing me to get the bellhousing up enough to line back up with the engine bolt holes. Thinking back now, I believe the hanging exhaust helped quite alot since it weighed down and tilted the engine back downwards, allowing proper tranny bolt alignment. And all of this was done while the car's front wheels were on ramps and the back was up on jack stands, no lift, in my driveway, by myself, with only a two ton floor jack to lift the tranny in place. I know it can be done and you don't have to drop the engine cradle. Really long ratchet extension bars and a swivel adaptor are a must, for catching those top housing bolts. The engine hangs, but just barely enough to get those tranny bolts back on.
BTW, if you do try dropping the exhaust like I did, unhook your upper radiator hose from the radiator first or it will put stress on and crack the radiator when the engine drops that far back. Good luck.
