ViperSRT10 wrote:I get my tires from a local junk yard for 15 bucks a piece
that works great while you are learning. once you start getting good you will realize a cheap used tire SUCKS. they are incredibly inconsistent, dont last long and generally suck all around
when you start having prolonged drifts (10+ seconds) you will realize what i mean by inconsistent. all of a sudden they can eithre GAIN or LOOSE traction almost instantly. ive had both happen and it can honestly be dangerous. if your speeds are up and you are going around a corner with no runoff or "out" if things get out of control bad things can happen if you spin or catch traction.
its all about prefrence and your budget. my tire WAS the Falken Azenis ST115 but they are no longer made. Ive also run on Hankook's and a plethora of other tires.
as a noob tires dont mean anything, just get the cheapest you can. get 5 good events under your belt then start worrying about what tires to run.
