majorg wrote:Air pressure should be set based on the vehicle, not on the tires. You can find recommened pressures on the driver's door jamb, and, I believe, it says 32-33 psi (cold). The psi rating on the tire indicates maximum safe pressure for this particular tire. If you're running cold pressures that high you are risking blowouts. Even on the track (I track 911, I know) you should try to avoid running air pressures that high. In short, risking blowouts and reducing contact patch and, therefore, available traction, isn't worth saving a little fuel, in my humble opinion.
I've driven my Audi at 39-40 psi, where as the ordinary tire pressure was suppose to be 33. I've done it for 50,000 miles and going more than 100+ MPH. It prolonged my tire life to 48,000 miles. And my Audi tire rating was at 130 MPH. I've had 2 Audi's and have over-inflated above the manufacturer's recommendation for 8 years and for over 100,000 miles - no blow out at 120 MPH or more.
The EX35 tire rating has a higher speed rating (163 MPH or more). The manufacturer's tire pressure rating is an 'average' and not a maximum setting. If you know cars, you should the know that that's industry standard practice for ALL car manufacturers. So you can definitely inflated it a few more PSIs.
You are very wrong about the tire pressure being dependent on the vehicle. All tires have a pressure limit, irregardless of the vehicle you're driving. One vehicle maybe heavier than the other, but the tire pressure is still the same pressure whether you set it at 33 or 35 psi. It's like you're saying that a bigger stone will fall faster than a smaller stone fall down - Wrong! gravity is the same.
