How have you been rotating them. I would say run your hands over the surface of the tire with an open palm towards the tread. If you feel raised edges on the inside edge of the tires you are starting to develop feather edging. This is a normal byproduct of alignment and is not a design flaw. With frequent cross rotation the wear can be balanced. I would also suggest getting a 4 wheel alignment. Your front toe should be set to between 0.02 and 0.04 each side. This will allow for less chance of featheredging without sacrificing road feel.EXcitement wrote:My EX is experiencing very loud tire noise after putting about 30,000 miles on my Dunlop tires.
You really do drive the hell out of that thing don't you.RioD007 wrote:You are lucky... mine were toast after 14,000 miles
EXcitement wrote:My EX is experiencing very loud tire noise after putting about 30,000 miles on my Dunlop tires. Is anyone else having this problem? The service dept. checked out everything last week and suggested that there was some "cupping" on the tires that might be the source of the noise. The tires look fine, there is plenty of tread left, but the noise is bothersome both at low and high speeds. Any thoughts or confirming opinions would be appreciated. I have never had Dunlop tires...maybe this is common. I would hate to buy new tires at this point, but may have to in order to return to the quiet ride i expect.
the Ziex 912s are a great tire. I had those for a bit before i swapped to Potenza S-02 pole positions on the TL -TheWife’sEX wrote:Speaking of Falkens, we have the 18" wheels, and we replaced the Dunlops about 2 months ago (at about 25k miles) with Falken Ziex ZE912. Looks like they're the only performance tire of the same size, they're about 2/3 the price of the Dunlops, and that model was recently ranked by Consumer Reports as the best high performance all season tire. That's the good news.
The bad news is that with only 2k miles on them, they're starting to show the same problem that started with the Dunlops at about 14k miles. The problem is not "cupping" or "feathering" - as many service managers and even techs would and have incorrectly called it - but heel and toe wear on the outside tread blocks only. When viewed from the side, there is a sawtooth like shape to the tread blocks, with the leading edge being slightly higher than the trailing edge. It can be felt by running the palm of your hand along the outside circumference. I wonder if that's actually a problem others on this forum are experiencing but mislabeling?
We bought the car with 12k miles on it, and it drove fine (although not 100% sure the tires hadn't already started to wear abnormally - in fact, they may have been relatively new, I never checked the tread depth). Went on a long road trip and about 2k miles in, started to get vibration in the front, mostly passenger side. Got 4-wheel alignment, balance and rotation halfway into the trip, but tires never "corrected" as they said hopefully would happen. Couldn't stand the vibration after a few more months and 10k miles, so bought the new tires (but skipped the alignment, which was likely a mistake).
After replacing the tires (bought at DiscountTire.com, installed at dealer), the ride was vastly improved, but oscillation on braking was more pronounced (just more noticeable since it was isolated?). Next visit led to resurfacing front and rear discs, then replacing front discs, at no charge to me (this is at about 26k) AND another tire balance, which they admitted wasn't done properly the first time. All seemed well.
Another 1k miles or so and we're on a Sunday drive yesterday - had very slight vibration again, but I figured maybe just the road/my head? On the way back, vibration was much more pronounced, so I checked the tires when we got home and noticed the early stages of the heel and toe wear. This went from barely noticeable to pretty annoying in a hurry (less than 60 miles).
Very ticked off, and very concerned that there's more going on than a slight alignment problem. I mean, can very slight heel and toe wear cause such a noticeable vibration, especially after only 2k miles? Besides, can't the car hold an alignment for more than 6 months? I've noticed mention on this forum of a steering rack issue, but the dealer says that has nothing to do with my symptoms. Anyway, it's back to the dealer tomorrow, probably for an alignment, and then I don't know what...
Sorry for the long first post - I'm new to this forum, but have been reading for a while, thanks for all of the useful info over the past year.
Living in the Northeast, I would agree that I'm more likely to need more frequent alignments than some down South or out West. However it would seem that an alignment should last more than 6 months an 8-9k miles, especially over the summer months (i.e. - April thru Sept). Since I had one in April, and the new tires on in Aug, I figured I'd go through the winter, then get one in the spring. Especially since the car drives/handles fine. I realize a car out of alignment specs can seem to drive OK and have imperceptible impact on the tires, but I find it hard to believe that it could cause so much damage to the two front tires in only 2k miles, and on two occurrences with two different tires (Dunlops and Falkens) in around 25k miles.JCL622 wrote:...however it would seem you expect to not need an alignment for X amount of miles. There is no set period of when you need one. It depends on where and how you drive. I used to drive my TL like a bat out of hell, as a result, i needed new tires almost every 9000 miles and i was changing my oil probably every 3500 not out of habit, but because the engine oil was running that low already ~ 35%.
anyway, you may not drive like i did then, but the environment around you may require that you do an alignment more often than you would like. Also, things like a bent rim (one really bad pot hole can do that) or slightly bent rim will also cause bad heel/toe rash and vibrations.
Thanks JCL662, and you were probably speaking to the thread in general, but to be clear in my case, these are 4 new tires, pressure is fine. Not sure how to check the rims (visibly they seem fine) to see if there is a slight bend to them.JCL622 wrote:anyway, if you can check the quality of your rims, actually make sure that the tires are really all evenly worn or better yet all equally new, tire pressure, and alignment, i am sure you will discover that the noise goes away.
Another very common thing is if youve had a flat and only replaced that one tire, you will get road noise as well...so there are a few factors to all of this.
Interesting. I suspect we aren't the only two, and some others that have complained about early tire wear are perhaps experiencing the same exact problem, but it just isn't being described the same? I think someone else raised the concern that it might be a suspension geometry issue, which would REALLY stink...ecosse wrote:This is a perfect description of what I have been experiencing since about 30,000 km. I want to get new tires but I'm concerned that it's a car problem not a tire problem and, like you, will be back in the same situation after spending a bunch of money for nothing.
