Ok, what i did do is, that on the tooth of where the aligning dot is on the cam sprocket, i colored that tooth in, to align with the timing covers and they all lined up. along with the marks that i lined on the sprockets the timing belt marks lined up as well. Basically all my marks are lined up perfectly before i spin the cranckshaft 720 deg, and the only mark that dont line up is the intake cam sprocket to the timing cover mark after the rotation. Im not second guessing you, but i have lined these up plenty of times to where the marks line up correctly with the reference marks i have made on the sprockets to the timing cover marks. Now what im thinking, which may be wrong, is that my problem might be my VTC solenoid. Im thinking this because the sprocket becomes advance after rotation, (a tooth before the reference mark on the cam sprocket) and if im correct the solenoid uses spring tension and oil pressure to change the timing on the intake cam right? If that is so, maybe the spring loaded when line the marks up, and after rotation they unload back into the rest position causing the mark to be incorrect. IDK sorry for the rambling, jus taking a guess, and I might just remove the solenoid and line the marks up again rotate the crank 720 degs again to elevate that being a possibilty. Ima look through the FSM and see how easy it is to remove. Thanks for the suggestions, please keep them coming.
Correction: The spring keeps the camsprocket in sync with the cam shaft, so maybe thats broken IDK just found this
http://www.google.com/imgres?imgurl=htt ... s%3Disch:1
just going to do some more inspection
