Ok this is about the best $79 I ever spent on this car.
Car has 215,000 miles
I actually was able to get the tensioner in and out without moving the engine. I had
about 6" of clearance between the car body and the access hatch (scroll down for
schematic on this thread) to work so I thought I could do it.
Not only did this eliminate the sound of the car sounding like a diesel at start
up but it has changed how the car shifted (Auto tran). It used to rev up pretty
high to shift out of first but now has a lower rpm shift change to second.
Generally the car has more power as well. I could tell it was "lugging down"
some between 30-40 mph but this problem has mostly disappeared as well.
I had thought for a long time the tranny was going out but now I dont think so
You must have an gentle attitude to make this repair.
The tensioner has two holes in the body to connect it to the engine block. Looking at
the old one there is a hollow piston with a long spring inside of it. Inside of the spring
is a short steel dowell which I assume moves inside of the spring-not sure of its true
function. On the back of the tensioner a oil passage area has been cut into the tensioner
body to allow oil into the body of the tensioner. There is a very small hole used for the
push pin to hold in the piston until it is set into position on top of the slack side timing
chain guide. Inside of the hole where the piston rides, there appears to be a place for
and o ring or some type of seal but I am not sure. I see the channel for a seal to go I think
Anyway the device appears to be a hydraulic device and uses a mechanical spring to
manipulate a piston to move the slack side timing chain guide. If you look close on the
schematic you can tell where the piston should push on the chain guide.
To replace it first I gave myself some more room but removing the power steering
reservoir, draining it etc. I actually just loosened the hose clamp UNDER the reservoir
from the hose closest to the outside of the car(on the passenger side) and pulled it out
of the way. It actually will slide up out of a plastic channel as well
Upon reinstallation, I just filled up the resevoir and cut the wheels back and
forth. The pump never squeeled or acted like it had air in it. Nothing to it.
Next I loosened the clamp holding the AC aluminum tube to the strut and pushed it out of the way
gently. I didnt disconnect the ac, just moved this component out of the way.
Get another ratchet and socket for your crankshaft pulley. Move it counterclockwise
You are creating some slack in the timing chain so you will have more room for your
installation. You may move the chain during this process clockwise and counter clock
wise during this process to manipulate the chain to create the most slack for your advantange.
Using a #10 socket and #10 offset wrench remove the access hatch. There are four #10
metric bolts. Upon reassembly, I just used some black sealant on it. The access hatch
bolts ride above the belts (yea) so I didn't need to remove the belts either. The hatch is
flat and doesnt have tabs to catch anything (straightforward to take off)
At this point you should see the tensioner (2 bolts) and where the piston is positioned and
protruding on the slack guide. Make a couple of marks on your timing chain cover where these bolts are to go back in for general reference.
The repair gets critical now because you dont want to drop any screws, wrenches etc into
your timing chain cover. I used the ratchet and #10 metric socket to remove the old timing
chain tensioner. The bolts are pretty long (2-3 inches). I stuffed some rags around the openings
of the case to prevent bolts from falling in the case. After unscrewing the bolts, the tensioner
easily came out. The bolts were easy to remove because they are only tensioned to a few inch
pounds. Note the bolts thread into the back of the block-there are no threads inside the tensioner
for the bolts. The holes of the tensioner must line up with the holes in the bolts. I have
probably overexplained myself now.
When you remove the tensioner, this the slack side guide will lean into where the tensioner will go. Don't worry-there is another bolt holding it in the case so it wont fall out. You can touch the chain at this point and feel how much slack you have.
I had some problems upon reinstallation but worked through them (whew!)
I figured out
the best way to install the tensioner was to get the bottom bolt in first. I hand tighted it first. This controls the position of the piston on the chain tensioner. It took me about an hour to learn this but you will need some leverage to push the tensioner into a position for the bolt to go in to
the top hole of the tensioner. Using the timing case as leverage, I used a Craftsman tire tool that was about 2 ft long with a slight crook in it to push/pull the tensioner toward the timing chain and up a little. I did this and screwed in the bolt at the same time-and it went in! Reflecting upon this
it would have been better to use a piece of wood to protect the case but no harm no foul.
NOW you can pull out the push pin!
Mine "clacked" into place pretty deliberately -it was in there pretty good after a little shaking and
testing
Reassembled
Turned timing chain at the crank around a few times to re-establish repair, crossed fingers,
and started
At first there was a little rattle, probably air. I started this morning and it was fantastically quiet
ok boss is back- back to work
