Ace2cool »
https://forums.nicoclub.com/ace2cool-u95120.html
Sat May 18, 2013 7:52 am
No, don't worry about the backing plates. If the lines on the belt match up with the cam gears, you'll be fine. But yes, count the teeth of the timing belt in between the timing marks just to make sure you have them all 100% correct. The specs for that are in the FSM under EM, I believe.
My backing plates on the passenger side are almost 2 full timing marks off. They're just there to help you find TDC.
