szh »
https://forums.nicoclub.com/szh-u149.html
Thu May 17, 2007 1:20 pm
Regular backups are essential ... even when you are not having a problem requiring a reformat and reload!! If you do not have a backup of your files, you could lose ALL your stuff in a heartbeat - if a drive goes bad, or the partition format is lost, etc.
The simplest thing to do is to get an external USB 2.0 drive (assuming you have a USB 2.0 port?), and, if you do not have any backup software, just use the Windows XP backup program. Make a full copy of the drive and go from there.
If you have difficulty keeping the system up during the backup, try pressing F8 during the boot and bring it up in standalone mode (without network support, etc.). This loads a minimum set of drivers and may allow you to complete the backup ...
Check back here if you need more info.
Z
P.S. And, I will emphasize again, you need to learn to get into the habit of doing regular backups to avoid a catastrophe. If you do not do this soon, and you lose the drive, you only have yourself to blame!
