ARKQX33V6 »
https://forums.nicoclub.com/arkqx33v6-u165721.html
Sun Aug 22, 2010 8:02 am
As Buzzman stated do a break adjust first before adjusting the hand brake. Remove the drums, both sides up, clean out the dust (vacuum), check for dirt rust and leaking oil seal from axle, you can lubricate things in place and not take anything apart if you are careful and take your time. Use high temp anti seize and just a dab at 3 points along forward and aft shoe next to rear plate, grease the brake cable and springs into the shoe holder of the cable. Then check the brake cylinder, look for leaks, wipe the rubbers clean.
Before putting on the drums clean the brake shoe surfaces with a block of wood with sandpaper, just make the shoe glaze free.
Put anti seize at center of hub so drum and axle meet and drum can come off easier next time. If drum is too tight back off the brake adjust to allow easy install of drum.
Clean the drum with brake cleaner as you clean the complete brake assembly before adjusting or greasing, use the brake cleaner and a rag to clean off any grease on the brake shoe.
All clean and adjusted and with the drum installed, adjust from the outer plate through a rubber hole or slot and adjust the brake shoes by opening or closing the distance that the shoes travel. Rotate the drum by a leveraged stick to see that the drum is not too tight. Do both sides.
With the rear brakes adjusted to proper height next try the e brake handle, pull up and count the clicks, go for 4-6 clicks. Try the e brake on the road, at about 20 MPH in gear pull the e brake handle, you should stop, release the handle if brakes do not release you will have to lube the cables points under the car. In 2 WD at a stop pull e brake up, car should not move, release e brake, car should move.
Test the rear braking adjustment, at 20-30 MPH do a typical stop, listen and feel does the car stop as it should, no excess noise, no spring noise, no grinding. You can verify that the brakes in general are good by stopping in a controlled way with no traffic.
The abs should not pulsate on a dry road, but if you are going too fast the abs could come on at excessive speeds.
The rear work about 20-30% of the braking force so that leaves the front doing 70-80% of t he work. My rears are still very good at 13 years original with just doing the fronts for the third time. This seems to be normal.
