Yet another update:
This time you can have up to 20 active registers (Which is the MAX that the Q45 ECU supports).
The timing can be corected to read 15* BTDC*
*To correct timing just go to the main screen->select "Arrange Registers" and select "Timing" on the very top-> Set it to 80-> Click save-> Click close and your done.
And I also convinced Isaac (the King of the laptop Consult) to add AAC duty cycle in percentage. So with that added we will know when its time to clean the intake again.
Download here:
http://ppastos.q45.org/Softwar...n.exe
Add the ScanTechNissan.exe to the "C:\Program Files\Nissan" folder and then start the program.
OBD Scan Tech Nissan ROCKS!!!
Thanks Isaac
