Sooooo.....I hope this page has helped many many Nissan fans!!!
However, I have not ever really had to depend on Datascan to troubleshoot anything...ever. I am posting a pic of my datascan screen and I need someone to look at the readings and tell me why it feels like it is not tuned correctly. It feels like it is supposed to be more powerful. My RB20DET is now in a Nissan Hardbody pickup, and I pretty much "adjusted" EVERYTHING under the hood trying to make it start and idle before I found a couple of wiring errors. Now I have no idea which sensors are tuned incorrectly.
I have a very tight-feeling clutch pedal and a stage 2 clutch installed when I did the swap, but when I leave a red-light, I have to rev/clutch a few times and it launches sorrier and slower than my KA24 sohc hardbody....it isn't supposed to be like this
I have to rev super high to spin the tires but even then it is a let down...
The readings you see in the picture at taken at IDLE.....I am most curious about my TPS, Timing, and Injection because those are the ones I "adjusted" back and forth. (and I am pretty sure my O2 sensor is not working...probably part of my powerloss due to running rich?
After turning the TPS down slightly and, more importantly, turning the CAS clockwise 1/2 of an inch or so.....It launches even worse, tends to backfire a little bit around 4-5k rpm, but it has better acceleration??? Here are the readings, at idle, after the two adjustments I just mentioned...
As you can see from before and after photos of the datascan software, I already know the TPS adjustment also dropped my rpms by about 1000rpm, and my CAS adjustment dropped my timing down significantly...
But what is the "perfect tune"?? For an idling RB20DET, what SHOULD these numbers be??????
Thanks,
--TJ
