elwesso »
https://forums.nicoclub.com/elwesso-u5248.html
Fri Apr 04, 2014 12:38 pm
You'll want to replace the dust boots/bump stops, and there's a couple other bushings and whatnot. practically speaking, things like tension rod bushings, sway bar end links/bushings and the sway bar bracket bushings will probably need replaced, also the lower control arm bushings and ball joints should be inspected... That's just for starters...
