1SickSilvia wrote:^Hey, get in line!!!!!!!!!! LOL. Thats my pic by the way
john_93 vert wrote:I have a number of pieces that you are looking for but am located in Canada so shipping may be costly.
1SickSilvia -since you posted first-- I have the part you are looking for -it has a number of cracks around the visor mounts- if interested pm me your ZIP for shipping cost
The tall one from a zenki or the small one from a chucki?ROOFLESS wrote:not a vert specific item...........
WTB S13 front bumper lip
Local to NC area preferred
You can use the piece around the radio from your Vert, just have to unscrew the 4 bolts that hold the AT plate (PRND21) and find the plastic ring/boot to screw back on.240vertsr20 wrote:WTB did a 5-speed swap and im looking for the plastic trim around the shifter that goes up to the radio as well as the boot and shift knob
turbo5upra wrote:92 vert project
I am going to let the old ladies project go. I'm going to find her something turn key and rather than send this car to the junkyard I thought I'd give you guys a shot.
92 came from cali. red.
Top was replaced by the previous owner, rear windows need work.. the plastic clips need to be replaced.
I bought this car for $1000.00 two years ago. it needed and engine as it had rod knock
comes with 2 engines. the original and one that I put in it. engine is almost all the way in. some vacuum lines and other odds and ends and it will be done
Car has aftermarket carpet in it.
I have to go with it new and not installed:
J30 rotors
New calipers and hangers.
Hawk pads
rear rotors
stainless lines
Comes with a set of 6 spoke spec v wheels with like new fusion hri's wheels need some tlc but should be able to make them look like new.
Top does not function it goes up and down by hand.
front clip has been removed and some of it is in primer.
I will included the gallon of primer I bought for it.
The underside of the car is almost rust free. just normal surface rust on stuff.
I bought non vert door panels for it because I was going to remove the pillars.
Price is 800.00 very firm, It will take some work but could be a very nice car.
I had thoughts of dropping it off @ the junkyard after I parted it out but thought since they are so rare I would give you guys a chance at it.
If it doesn't sell I will part it out.
Pics will be uploaded and I will post a link tomorrow.
i have the plastic boot if you need it240vertsr20 wrote:WTB did a 5-speed swap and im looking for the plastic trim around the shifter that goes up to the radio as well as the boot and shift knob
do you mean the shift boot? and so im assuming you dont have the plastic trim then...mmm240 wrote:Ii have the plastic boot if you need it240vertsr20 wrote:WTB did a 5-speed swap and im looking for the plastic trim around the shifter that goes up to the radio as well as the boot and shift knob
The plastic boot that goes under boot you would normally see in a manual car240vertsr20 wrote:
sounds like it might be what im looking for....would u be able to send me a pic ill take it off your hands immediately if its what i needmmm240 wrote:The plastic boot that goes under boot you would normally see in a manual car240vertsr20 wrote:
I may want the package deal! Where is the car?turbo5upra wrote:92 vert project
J30 rotors
Hawk pads
rear rotors
stainless lines
Got a pic of that part240vertsr20 wrote:thanks man its greatly appreciated
I have this piece. Check your PMs or email me. [email protected]music24 wrote:WTB:
The rubber driveside seal that is attached to the convertible frame that the window slides over (see picture, the red arrow is pointing to the part)
Are you looking for the little box with the two up/down buttons that sits in the center console? If so, I have one. Email me if you need it.bgoodwill wrote:WTB: Looking for a convertible top quarter window switch connector rear jumper. (It's under the console -rear windows switches can be routed around it, but then don't go down with the top switch, so you have to use the individual switches on the console - know what I mean?) Please send price including shipping to zipcode 97378. Thanks.
