I've been searching the archives and found this:
zerothread?id=124899which led me to the quest to drop the Q using OEM Z32 parts.
I used OEM Z32 springs, upper mounts, and KYB GR-2 replacement struts for the FRONT ONLY (I didn't start on the rear yet).
(1) The two bolt holes on the strut towers need to be filed slightly closer together to accept the 300ZX upper mounts.
(2) The lower mount on the Z32 strut is too small to fit onto the Q's lower mount stud. The correct way to fix this is to have the OEM lower strut bushing from your old strut (or new if your anal) and press them into the Z32 strut.
Bolt it together and voila! Remember, its the fronts only. The rears are cut/blown oem G50 struts.
I'm looking into other options to get similar results in the rear without cutting any springs so stay tuned! Im open to your negative and positive feedback.
--------------------UPDATE--------------------
For the rear I used:
-OEM Z32 rear springs-Z32 FRONT struts-Q45 rear upper mount and bumpstops (centers had to be enlarged using a file)-5/16" thick, 2" angle iron to fab up some adapters
The adapter was simple enough to make. The rear spring didn't completely seat in the lower spring perch so I used some 1/2" heater hose to center the spring onto the perch. The piston of the fr Z strut is thicker than the Q's piston so in order to use the Q's upper hat and bushings, they had to be bored out with a file. I'll snap a pic of the adapter when I get a chance.
I've ridden with it like this since saturday with no problems. It rides SO much better than my previous setup. Here's a pic:
Modified by thejapino at 1:54 PM 3/4/2008
Modified by thejapino at 1:59 PM 3/4/2008
