Thanks. I checked the diagram and it would appear based on that diagram that it would be, but I don't see it.Q451990 wrote:There's a decent diagram of it's location on BR-57 in the FSM. It looks like you might take the radio and climate control head out to get to it?
Heath
I'm talking about the TCM that is supposed to have an LED blinking light to tell you what might be faulty after checking the number of blinks on the TCS in the trunk. My TCS is blinking 13 times, so as per the FSM and various threads on here suggest, I should then check the TCM to see how many blinks are on there to guide me into the direction of how to fix this issue. But I can't seem to find it. Making it more difficult, there are (3) different TCMs aparently, so I'm not even sure what I'm supposed to be looking for. Based on what I read in the FSM, it would seem like the TCM that has the blinking LED lights is located near the brake pedal somewhere, which it's not cuz I looked everywhere underneath the steering wheel and nothing under there resembles that box at all.Infinitiguy19 wrote:Assuming your talking about the Throttle Control Module and not the (Automatic) Transmission Control module or the Traction Control Module. Then it under the dashboard. The glove box must be removed to gain access to it as it is near the passenger side air bag.
Is my problem most likely the secondary throttle position sensor in your opinion? At this point I think I'd rather start throwing money at taking a logical guess at what might be causing the problem than looking for a box that isn't anywhere to be found.Infinitiguy19 wrote: Check the harness to the secondary Throttle Position Sensor. The wiring or the sensors itself could be the issue.
Well, I drove it. I parked it, went into the trunk, pulled down the back part, and counted the blinks - twice. Both times it ran as 13 blinks. My TCS & Slip lights have never blinked. As soon as you turn the car on, they just stay on. Do you know where the TPS connector is located? The FSM has a diagram and again, at least to me, it doesn't look like anything underneath my hood.Infinitiguy19 wrote:Did you drive the car 19 MPH to get the code 13?
Are you sure you counted the number of blinks correctly?
Were the TCS and SLIP light blinking as well?
I would say check the connection to the secondary TPS Sensor first, make sure its clean....
So I found the TCM. I pulled the black plastic cover underneath the dash off and stuck my head all the way underneath and with a flashlight i was able to find it. But here's the thing, the LED on the TCM is not blinking. Based on what I read in the FSM, after you check the TCS control unit and count the number of blinks (in my case it was 13), you are supposed to then check the TCM and count the LED blinks on there. But my TCM isn't blinking, so what am I supposed to do? The FSM doesn't mention anything about what to do in that situation. Any ideas?Infinitiguy19 wrote:See page BR-57 for the location of the secondary TPS.
If you drive the car at 19 MPH for at least a minute. I am fairly certain the two dashboard lights will blink.
It appears the TCM is next or very near to the instrument cluster. Lucky for you I guess. When you get to it check the wiring to the TCM as well.
mattd1979 wrote:From what I have read, the TCM module is supposed to blink two sets of 5 if all is good for 55 and blink whatever the problem code is. If it is steady red then it sounds like the TCM itself may be bad. One of the descriptions mentioned for code 13 of the TCU is if the TCM has entered fail-safe mode (TCM has failed) you will get a 13. You will also get a code 13 if there is a problem with the secondary throttle opening signal or primary throttle signal between the TCS and TCM.
Thanks for your input. So is it safe to assume the TCM unit itself has failed since it's not blinking it all? I just don't want to have to buy another unit, plug it in and have the same problem. The FSM is pretty clear that if the TCS is blinking 13 times, it's one of those three possibilities as you said. So if it was your car, would you just replace the TCM unit to start with since it appears to not even be working?mattd1979 wrote:The way I understand it is the TCM should always be blinking a code 55 repeatedly if it is good. If there is a problem with something else then it would blink the specified number for a particular sensor or problem area. I read that for code 13 that it is one of three things. It is either the secondary throttle opening signal, primary throttle signal between the TCS and TCM, or the TCM has failed.
Sorry so late to respond to this thread, but I had put this issue on ice for a moment. I'm taking my dash apart again sometime this weekend for the 1,836,873rd time and if I can somehow access the TCM from above, I will let you all know. I'll even take pics since apparently no one in the history of this board has ever had this issue but me. I did read something in the FSM that indicated that the TCM gets power from the secondary throttle position sensor (even though that doesn't seem to make any sense whatsoever), so perhaps my sensor has failed, thus causing no lights on my TCM. I really don't know. If I can't gain access to my TCM to remove it, then maybe I will just buy a new secondary throttle position sensor and see if that fixes it. If not, I really don't know what I'm going to do.marcyprojects wrote:Any resolution on this at all? Im trying to debug the exact same issue with my 93. Got the car with the TCS off light on only, slip is not lit, finally checked blinks the other day. 13 blinks. Checked the secondary TPS connections and it is solid, all contacts are clean. Ive swapped all the typical fuses and relays, alt and battery are new. I also noticed that after I disconnected and checked the tps or after the battery is disconnected for a while, the tps light is dimmly lit but not off? I can see the light flutter as I press the tcs button in the car upon starting it up. Eventually it becomes solid after about a minute.
Really want to get this stinkin light off, annoying the crap out of me as it is the last warning light I have yet to clear.
