Taillights and corners wont work
04LEMASS
Car: 2004 Nissan Pathfinder LE Platinum
-K&N Air Intake
My tailights and corner lights wont work but the blinkers and brake lights work. I installed led reverse lights so i though that could be the problem but i put the stock ones back and the problem is stillthere. I also messed around with the license plate lights installing an led one and now those dont work. Any ideas
Towncivilian
2007 Nissan Altima 2.5L CVT
2012 Infiniti G37 Sedan 7A/T
Your "TAIL" fuse in the engine compartment fuse box is blown.
04LEMASS
-K&N Air Intake
Wow i shoulda known the check, forgot there were fuses under the hood. Thank you towncivilian!
