MrCrowley »
https://forums.nicoclub.com/mrcrowley-u247018.html
Fri Jan 23, 2015 10:12 pm
I have a 95 Q45. The car had been in storage for about 3 years. The car was put back into service back in Sept. The car has been running fine, not a problem at all. All the sudden about 2 weeks ago, the Tach started acting funny. It looks like at start up it goes to about 1000 or a little higher. Then if the car was to sit in the same position and idle, the needle will climb to red line, and past. sometimes it will bounce out and star reading correctly, but on the next start up it starts the same issue. This went on for about a week, then the car started to stumble. It would act up until I could get it up on the highway, then it would run fine. It may run fine for several starts, but will again start stumbling again until it can be either floor boarded, sometimes correcting the issue for the rest of the drive and may not have a problem on the next startup. But today, it started acting really bad. It kept dying at every stop. I took it to a shop, they could not diagnose the issue because they did not have the diagnostic machine. They were unsure what the issue would be. I was wondering if, first...could the issues be related? I need some help on figuring out what I need to do o get the car in proper working condition. trying to take it to another shop, but this is my only mode of transportation.
