C-Kwik »
https://forums.nicoclub.com/c-kwik-u426.html
Sat Jan 25, 2003 3:22 pm
The ends attach to the lower suspension arms, while the center is held against the chassis or subframe. In all honesty, if you don't know this already, I wouldn't recommend making any until you really know what you are doing. They are quite sensitive to the stiffness. Especially in how stiff the front bar is in relation to the rear bar and vice versa. Having a sway bar too stiff on either side can cause poor handling characteristics. It takes some amount of test and tuning to really make a good set of sway bars.
