Sway Bar s13 with rb20det
LeD ippen
Car: 1993 Nissan 240sx SE
Okay so i finally have a sway bar. To have an sway bar in s13 with an rb20det using hockey punk mounts and r32 crossmember with a nismo brace. you need spacers ether way to clearance oil pan. my current setup is suspension technique front sway bar, daft innovations sway bar spacer, nismo brace, and r32 crossmember with hockey pucks. even with spacer clearance is very minimal but it will not likely hit unless the wheel drops far enough. even then it will hit nismo brace first if the you have coil over that drop that much.
driving for a year without a sway bar makes a difference. to help for a while i got a cusco front strut bar made for ca18det clear stock intake mani. it really help with the sway and spongy feeling up front. now with the sway bar bumps feel smoother because the wheel does not drop as much but you feel more bumps because both wheel are connected now.
