Big-Bird »
https://forums.nicoclub.com/big-bird-u44704.html
Mon Oct 02, 2006 4:49 pm
Doing the conversion on a non-supercharged 3.3 is very ambitious, and to my knowledge a successful attempt has not been written about in any Nissan Xterra or Frontier Forum I have ever seen. ( And there are a bunch of forums out there) Here's some numbers that you should be aware of and may explain why I haven't seen any records of this.
The 3.3 is a torquey engine by it's very design. It's a puller not a racer engine. In my opinion that's why the Pathfinder was later upgraded to the more powerful 3.5L, which was rated at 240HP with about 280 ft/pd of torque. That engine has some serious promise and could be an option for an engine swap! ( NOTE Always grab the donor's computer )
For 2000-2001 the normally aspirated Xterra/Frontier 3.3L is rated at 170hp with 200 ft/pd of torque at around 2000RPM!
In 2002 the basic 3.3 was uprated to 180 hp and 210 ft/pd of torque.
The Eaton Supercharger, introduced in 2001, was engineered and designed in Japan specifically for the 3.3L and it bumped the 2001-HP rating to 210 and 240 ft/pd of torque. That Eaton blower must be run on Premium Fuel or you get pre-ignition trouble (or pinging as it is sometimes called). Add to the fact that you have to change the hood, because the blower sits higher than a stock intake system, get an intercooler, SC Model computer with the complete wiring harnesses and possibly the instrument cluster with the boost gauge and you end up with a costly conversion. Not a big gain for that much money. Don't expect to get much more than 220 from a Blower equipped 3.3L engine without doing extensive engine work. A reputable machine shop can better advise on that with piston types, crank shaft work, compression ratios etc. I'm not saying it can't be done but there is a bit of planning to be aware of first.
There are other options that would be more cost effective and it could be a real sleeper engine if you do it right. For example......
1) A 3.5L engine conversion from a Pathfinder or QX4. Serious sleeper potential!
2) Check out Spencer Low Racing. They have a wide range of upgrades for the 3.3 engine that includes but is not limited to; SLR Headers, throttle body machining, throttle spacers, hi-lift cam shafts, complete exhaust systems from the headers back (These upgrades are not all 50 State legal though).
3) For Catalytic Back Exhaust systems you have more options. You could go with Borla, Gibson, or even have a muffler shop fabricate some 3" pipes with a hi-flow muffler like a Dynomax or something similar.
4) Switching to a cold air intake system like Volant, AEM industries, or K&N is another option you also have.
By the way don't believe all the claims of how much HP you will gain by doing an upgrade. They are usually worded like this 'This product will give UP TO 15% gain in HP.' The key word here is UP TO. Which means maybe.
What you really need to ask your self is what do I want this engine to do?
Be fast? Be a good tow rig?
Each Honda's for lunch?
I always wondered if the 3.3 could be turned into a 3.4L or 3.5L with some machine work and a new crank. Get the right rod, piston, and camshaft combo and a stock 3.3L could really be a menace . That would mean you should have a 5 speed with the right diff gears and a centerforce clutch.....ohh man I'm drooling!
