marksport wrote:
Lysholm makes a 2.4L supercharger. Kenne Bell makes a 2.8L and Whipple makes an enormous 5.0L units that will likely flow for 1300+HP.
Been to their websites, and low and behold NONE of them list all the important specs like max impellor rpm, max approx hp, max boost, max flow (cfm etc). A couple of specs are available, however to try and custom fit one to an engine like mine is damn near impossible. I see Kenne Bell does a kit for a shelby 500 which is 800hp. This is close but still short of what I am tryingh to make. Why dont these guys want my money? Where is their serious info? I click on Technical and get an engineering drawing, or a larger throttle body.sheez thanks guys!
o answer the above Q, with an 'unknown' or tested engine you make a good educated guess of a pulley size and bolt one on. Your boost is basically controlled by the size of the drive pulley. The style of blower will determine what rpm the majority of boost is in. So its simple, test a few pulley sizes to get what you are after boostwise and youre done. That's the usual way that I am aware of.
Ok now that I feel better does anyone know of a twin screw which is good for a max of 950 odd hp? This is a bit above what i am aiming for but some in reserve. I know you (mark) said one is theoretically good for 1300hp but none of their info stated that. Otherwise its the Procharger D1 I have which is going on...
