supercharged 240 with itbs and intercooler
240cp
Car: 95 240sx
hello everyone my first post just wanted a little feedback also how do you post pics
240cp
Car: 95 240sx
240cp
Car: 95 240sx
daconkiftador
Car: '92 Coupe SE, '83 Rabbit GTi, '91 Golf GTi
Is your hood going to have issues with closing shut?
Florida240sx
Looks fun
crzycav86
Car: 93 Nissan 240SX KAT
it looks neat, but i dont see how the supercharger connects to the intake stream...?
can you explain how you made it work? i'm curious and fascinated.
Florida240sx
My guess is he has a pipe at the back of the SC that runs down like a downpipe, up the front to the ic form passenger to driver's, then up and mates to the one you see...
frsh13
Car: 1991 240sx coupe
crzycav86 wrote:it looks neat, but i dont see how the supercharger connects to the intake stream...?
WDRacing
Other then lying the SC under the intake manifold what are you doing?
240cp
Car: 95 240sx
i know it looks crazy like that but those pics were while i was test fitting but now the supercharger plate has a outlet welded on to it comes out just under the water inlet then routes back to a rb 20 side mount intercooler then back to the intake plenum
240cp
Car: 95 240sx
oh and yes the hood is going to have to be louvered
WDRacing
The idea of having an output pipe rather then having the SC bolted directly to the intake manifold is fantastic. With the air charge cooled, you can easily run 15psi with the SC.
The ITB's are not my thing, far to much involved in that project for the benefit, but thats for me only. I'd fab a long runner manifold and have the SC go through a FMIC. With 15 PSI from the SC, you'd be able to run a HUGE turbo with NO LAG to speak of and make insane amount of power.
But just the SC alone will make a wicked fun daily driver. You'll have to post up pics of the fab process from here on out. This will be a fantastic article.
WD
240cp
Car: 95 240sx
preciate the compliments as i have already run into probs with the itbs and am going to remove them and do what you said with runners in between the mani and plenum
KATwo40
Car: 1993 240sx KA-T
What problems did you have with the ITB's?
240cp
Car: 95 240sx
i need to post pics of the final product but i dont have any right now but as it stands right now i have the supercharger under then mani and itbs with a plenum put the iacv and the aac valves on the plenum and wired everything as normal minus the throttle position sensor i spliced them together using the stock plug and the suzuki sensor also i have clearance problems between the plenum and sc because of the itbs and dont know if the safc2 can recognize the suzuki sensor when i got the safc2 wired in and did the sensor check and monitor mode the throttle was at a steady 20 percent and wouldnt come down even after i adjusted it but i didnt think that would affect it from starting i did crank on it alot trying different things could it have jumped timing
540sx
Car: Nissan 240SX
in the pic it looks like there is no room to connect the coolant line to the inlet on the motor.
but thats cool. hope it all works out.
neverlift
almost two years old
480sx
Car: 1996 Pearl White 240sx
Seriously doubt this thing ever happened..
WDRacing
I did see some posts that were almost complete...just not in this thread. Something similar to has been done a couple times now, but without the FMIC.
My idea was to mount that dude over the exhaust mani and run it through the FMIC similar to the Miata setup. Instant 15psi FTMFW...I still may do it that way...I dunno.
WD
240cp
Car: 95 240sx
It happened, I had it complete for a few months and enjoyed every minute of it. Only prob, i was blowing couplers all the time. Pissed me off. I tell you what it really is fun having instant boost like that. Anyways this is what the final product was.
By the way how this thread get brought back. Also it really was waste of good fab work and time. I probably could have just went turbo and got pretty close to the same result. With all the piping and such. But i wanted to do something that was a little off the beat'n path.
480sx
Sweet, what happened to it? Why arnt you driving it now? That was a lot of work just for a few months of fun.
SCd cars are a crap ton of fun to drive, everyone dismisses them until they drive one. Def was not a waste IMO, a supercharged 240 must have been a blasstttt on the street.
The ITB's were kinda a waste.. Lol, but w/e.
450SX! wrote:in the pic it looks like there is no room to connect the coolant line to the inlet on the motor.
Thats how it was brought back.. Nico now shows all old threads when searching.. Or something like that.
240cp
Car: 95 240sx
Well, i took it off the road for a rebuild. Was still running when i did but there was a bunch of blow by and compression was way down. Something like 140-140-155-130. Cant remember now. Then i had a wild idea of putting a 6.0 lq4 from a 2500 truck in it. Well money got real tight and now just rebuilding it back to basically stock. Then redoing the supercharger with small changes (hopefully for the better) and going to feed it with a small turbo. Been doing some looking around and for me that is the best route. We'll see? Thanks for compliments and yeah itb's were a complete waste of time. LOL
neverlift
it was a syck waste though like purposely going out to pwnt a set of tires....
I'd suggest, fmic....and putting lips on your pipes heard hair spray works
MastaYu
Car: 92 Nissan 240SX SE HB
Very unique build
240cp
Car: 95 240sx
I had a front mount from godspeed in there first and it was just way to much area for a eaton to fill up. So basically i never saw boost. That's why i changed to the small side mount. I was working on a custom intake manifold that would incorporate a air to water core inside and the supercharger would bolt to it, but it seems to be to much for me.
I have limited tools, and just not patient enough for it either. I am redoing things as we speak and gone incorporate a air to water intercooler this time. I'll be sure to post everything as i get further along. Again thanks for the compliments.
