You're right man, I'm aiming for standalone AEM. I'll search more info about the engine harness that is already made and just plug and play. Searching for RB20 parts ain't no joke, I'm starting getting headaches.themadscientist wrote:
Don't waste your time looking for a POS factory harness and computer. Get an aftermarket system now and skip that dealing with factory BS step.
That ain't happening. I have seen 400hp RB20s but they were heavily built and I don't think a single one was truly an RB"20". The 2.2 was the s*** there back in the day. Those sorts of power figures are going to call for huge amounts of boost and increased RPMs. Pistons, cams, lifters, gasket, oil pump, etc, all will need replacement. The rods might hang and the crank is fine, but both will need to be prepped and balanced. The head will have to be seriously hogged out to even try flowing that much air. I hate to be a killjoy but I would be surprised if you could crack 350hp with the RB20 without a lot of R&D and a couple blown motors along the way.R32RB20DET wrote:As far as for my goals, I want to get the motor up running for stock setup. But I want at least 400-450 hp with stock internals. Anything higher I may have to upgrade my bottom-end block.
changes to plan.R32RB20DET wrote: Plan A:
Standalone AEM
Wiring Specialties Pre-Made Harness
550cc Injectors
Z32 Maf
Custom FMIC
Top Mount Manifold
Tial 38mm Wastegate
Master Power Turbo T04E
Yeah, I was thinking 720cc or 850cc but it will be a gas hogger. I guess I'll lowered my hp down haha. Around 300-350 hp and I think it's good enough for drifting. I think I'm expecting to much from the RB20. Yeah, once I get standalone I don't need a maf anymore...I do forget things haha.themadscientist wrote:That ain't happening. I have seen 400hp RB20s but they were heavily built and I don't think a single one was truly an RB"20". The 2.2 was the s*** there back in the day. Those sorts of power figures are going to call for huge amounts of boost and increased RPMs. Pistons, cams, lifters, gasket, oil pump, etc, all will need replacement. The rods might hang and the crank is fine, but both will need to be prepped and balanced. The head will have to be seriously hogged out to even try flowing that much air. I hate to be a killjoy but I would be surprised if you could crack 350hp with the RB20 without a lot of R&D and a couple blown motors along the way.R32RB20DET wrote:As far as for my goals, I want to get the motor up running for stock setup. But I want at least 400-450 hp with stock internals. Anything higher I may have to upgrade my bottom-end block.
Standalone AEM
550cc Injectors
Z32 Maf
Custom FMIC
Top Mount Manifold
Tial 38mm Wastegate
You are going to need bigger injectors than that for 400+. 720s would provide you ample cushion, 555s are barely keeping up.
MAF? Lose that s***, you have a standalone, why go backwards? use a MAP reference.
What's your setup and hp made at the wheel?SullivanRacing06 wrote:run 800ccs, aem ems, aem 3.5 bar map.
i switched to a aem ems and 3.5 bar map set up, huge diff!!!!!
So you're saying you made over 600HP at the wheels with an RB20 and less than 18 PSI??? I'm sceptical so do you have any proof?SullivanRacing06 wrote:no emanage..
600+ at the wheel w/g wasnt holding boost over 18psi)
umm no emanage
I heard that I can use the KA power steering pump and mock up a new bracket? I remember seeing this post on nico. Correct me if I'm wrong.Yellow4g63 wrote:better hook up the Power steering pump or it's just going to suck to drive in a parking lot.
So you're saying to able to use the KA power steering pump I have to use RB25 power steering bracket?Yellow4g63 wrote:You need the RB25 power steering mounting bracket that goes on the motor.
