float_6969 »
https://forums.nicoclub.com/float-6969-u780.html
Sun Mar 31, 2013 10:46 am
You can move the engagement point with a stanalone (and I did), but there was never a perfect transition there. You would have to attach the valves to a servo so that around the switchover point the valves would be kept at a partially open point. Do-able, but harder.
The flow between the 8 and 4 port heads is negligible. Technically the 4 port head has more area, but only a small amount, and round ports are better at moving air than oval ports, so it basically cancels out.
I can see what you're saying about the injectors, but I think the higher port velocities created by separate ports create better atomization before the combustion chamber. Ideally, there would be one injector per port, with one injector running at lower RPM's and loads. When that injector reached high load (80%?) then the ecu would switch on both injectors at a rate equal to the flow rate of the single injector (half of duty cycle of the single injector, only using two injectors) and continue that until redline/the load drops back down. It would probably also be associated with the opening of the valves as the 2nd injector couldn't begine to fire until it opened. I had planned on implementing this concept, but when the oil filter failed and ruined the head, I decided to use the 4 port head I had already instead of trying to source another 8 port head and starting over with it.
I honestly think the 8 port is the better head, and if it was paired with a manifold that was optimized for the 8 ports, that it would be the best performer.
