RoCkDj »
https://forums.nicoclub.com/rockdj-u234556.html
Sat Apr 12, 2014 9:04 am
Hi guys , I'll start off with some basic list of mods on the G35 2006
Its fitted with wiseco forged 8.5.1 compression , turbo charged with HKS 3037 kit boosting at 1.3 bar with 450whp . Management I'm using Osiris Up-Rev. So this is my problem.
One day as usual driving the car suddenly starts to misfire sputtering.. manage to limp my way to the workshop. So we shut it off , and tried to start again but it wouldnt start , with acc turned on , the CEL light would blink and with some clicking noise on fuel relay at the IPTM . after a few clicks the CEL light will be gone and the radiator fan started spinning. So the mechs decided to check on the electrical faults and found 2 of the ignition signal from the ECU was broken and it was touching , so the next best thing to do would be wiretape it back , check all the groundings , secured done.. The blinking somehow stopped, CEL light recovered . We decided to give it a go , crank but no start... Noticed some smoke coming out from the coils..fried 2 coils.. Electrician decided to do some voltage comparison with other G35 . Mine was strange, with just ignition On , the ecu is sending a 4v signal on my 1st coil and 0.3-0.4v to the rest of the coils... that's without cranking or anything.. So basically my coils fires up even without cranking signal.. How can that suppose to happen ? A bad ECU ? we changed everything possible, even a new condenser. Yet still its the same.. Any solution for this ?
