Bills »
https://forums.nicoclub.com/bills-u219002.html
Sat Apr 20, 2013 12:30 pm
Hello,
Today I decided to try and fix my 2004 Pathfinder, I have been using the screwdriver to shift for about a year now.
I pulled and tested the solenoid, which does work outside of the system. I checked the wiring with a multimeter. The white wire is being grounded when I press on the brake, but there is no voltage on the other wire, or the other wire that goes to the little switch. I checked all of the fuses and relays that seemed to be relevant, next to the steering column and under the hood in the two separate boxes. But I cant find any bad component. One thread said that the relay was under the console, so I pulled the console, there is no relay, only the airbag sensors.
Any ideas?
The link in the last post seems promising, but it appears to be dead. I have not seen any wiring diagrams for this.
Thanks,
Bill
