Last night I parked my car outside a shopping wall. After I return back to my car, I immediately noticed something strange happened:
-The clock on the upper right corner of the information screen (the screen that is between the speed and rpm) was disappeared.
-There was only temperature, centered on the top row
-The temperature is constantly changing between 8 - 9 - 8 - 9 - 8 in a rhythm (normally outside was 1 or 2 degrees)
-The unit (centigrade celsius) was flashing (the outside temperature alert was disabled, even if it was enabled, in that case the number should flash as well. I never saw the unit flashing before)
-The brightness of the whole lights returned back to 75% (normally it was 100%)
-All other settings were there (radio presets, maintenance and tire mileages, average fuel consumption, average distance, ...)
I put the clock back, increase the brightness. Run the engine...wait for 2-3 minutes. Turn off the engine. Turn it on again and it became normal:
-Temperature 1 degrees, C' is not flashing. Normal
-Time upper right corner. Normal
-Brightness full. Normal
So what do you think? it is like someone disconnected the battery or reset the software (although some of the settings are there). I am confused and scared. It never happened before. I hope it is not the computer of the car. The car is under warranty now, but I can't replicate this error again if I go to the dealer... and what if it is a sign of a failure and what if it fails after warranty expires
