Sticking popup headlights? Here's an easy fix!
usdm_180sx
Car: 1993 Nissan 240SX base S13
The right headlight on my car was sticking in the up position after I would turn off the headlights so I decided to look into fixing it (New headlight motors are ~$250 from the dealer and getting a used one only prolongs the inevitable sticking problem)
Anyway, the headlight motors have motor brushes that wear out over time (after 13 years they can definitely wear out)
What I did first was take off the headlight motor knob and cover (circled in red), then bent the brushes so that they touch the motor and added some contact grease. Reassembled everything and now they work just fine!
I'll post better pics tomorrow.
TotallyStock
Car: 1992 240SX Totally Stock 82k Miles
Very Cool ---- I'll try that with my sticky headlight ---- Thanx!!!!!
srpowered240sx
Car: 90 240sx-sr, 92 F-150, 00 bmw 323ci, 1991 s13 coupe, 99 F250 Dsl
bitchin, my brothers car is doing this, hes gonna love you.
usdm_180sx
Quick heads up. There's a little spring that holds the motor brushes together. Be careful not to let it snap off! You can get another one at the yunkyard though
ghettoslide
Car: '90 240sx, '91 240sx, '98 DSM, '05 Avalance
My left light 0n my 90 has started doing this, only when i turn lights off it stays up until i pop the hood then it goes down, Something needs to be aligned
usdm_180sx
ghettoslide wrote:My left light 0n my 90 has started doing this, only when i turn lights off it stays up until i pop the hood then it goes down, Something needs to be aligned
WTF alignment? Sounds like the motor brushes in your left headlight motor don't have any contact but when you pop the hood they touch meaning they're worn out. Sounds like my fix should work for you.
TotallyStock
usdm_180sx wrote:Quick heads up. There's a little spring that holds the motor brushes together. Be careful not to let it snap off! You can get another one at the yunkyard though
A trainload of thanx for this detail...thanx for the heads-up! I will look out for that when I start tweeking into the motor ----EXCELLENT POST!!!!!
ghettoslide
I was thinking that maybe the hood shifted on it's hing and is applying pressure on the left. I just moved down a bumpy *** road and this started.
