Steering rack bushing replacement
00pathyse
Car: 2000 Nissan Pathfinder SE
2007 Nissan Altima 3.5 SE Sedan
Has anyone replacedthe bushings on their steering rack? My driver side bushing has gone and I need to replace. I'm wondering how big of a pain it will be. Has anyone done this job and give some advice? Thanks.
ltsnotme
Car: 1996 Pathfinder XE 4WD
Yeah, a pretty simple job: jack up the front, unbolt the two brackets and replace the bushings. Might need a breaker bar for those bolts.
00pathyse
Did you have to remove any hydraulic lines? Or anything else to get the socket in there? Looks like a tight squeeze. Thanks.
ltsnotme
00pathyse wrote:Did you have to remove any hydraulic lines? Or anything else to get the socket in there? Looks like a tight squeeze. Thanks.
Nope, I managed with just a socket wrench and a short extension I think. The upper bolts were pretty hard to get to though so if you have a universal joint, it would probably help.
ballsie
I just replaced those bushings a few months ago. I doubt the truck was in the air for 20 minutes. Pretty easy job. The bushings are $20/pair at the Nissan dealer.
00pathyse
Thanks alot.
I ordered a pair of Ricochet polyurethane ones (made in the usa) for 30$. Never going to have to worry about the driver side one from rotting out.
ballsie
yeah, my driver side bushing was completely gone and my passenger side bushing wasn't far behind it. The entire steering rack moved from side to side.
00pathyse
Ouch. Yea mine definetely has some play and makes a clunk too. How was the clearance from the frame to get the old bushing out and the new bushing on?
00pathyse
Got the bushings replaced today. Wasnt too bad, struggled a bit to get the driver side one on. Had to loosen the high pressure line on the rack assy to get the socket on the top bracket bolt so i lost some fluid. Steering is noticeably tighter and smoother now.
9899pathfinder
I wrote the steps I used here:
Broken steering rack bushing
broken-steering-rack-bushing-t578475.html
